Other Parts Discussed in Thread: TPS62827
Just want to confirm one thing regarding connection of power good pin for TPS62810-Q1 converter. Application note/ Schematic for similar converter (e.g. TPS62827) shows that power good pin is connected across resistor to input voltage rail and on TPS62810-Q1 this pin is connected across resistor to out voltage rail. Is there any reason for this?
Regarding topology converter and type of this pin (open-drain) we suppose that it can be connected either to input or output voltage rail. Is this correct?
Thanks for your time and hope to hear from you soon!
Kind regards,
Milos
