TPS92660: Need design help
Part Number: TPS92660
Other Parts Discussed in Thread: TPS92640,
I have been using TPS92640 in my existing design. Unfortunately the part is out of stock. I am thinking of moving to TSP92660, need suggesstions on design. Do I need an external buck regulator to regulate the voltage? Here is my existing design, my main input is 48V:
Here is the information of the LED I will be using:
  1. Supply voltage: 24V
  2. Width: 8mm/10mm
  3. Color : Warm white, 3000K
  4. Wattage: 26W/m
  5. Length : 3.24meter
Lumitape SW 28N210-XX80-240708-YYY.pdf
2835-160D-DC24V-Single Color Datasheet.pdf
