LM5143-Q1EVM-2100: Modify EVM config to single output, two phase
Part Number: LM5143-Q1EVM-2100
Hi Team,
A title, if I want to set EVM config to single output, two phase. Should I modify the red connection only? If there is any part that I need to modify, please let me know. Thank you.
Roy
  • Hi Roy,
    You can remove the COMP2 compensation network and connect the jumper that ties the two outputs together. Also, use the quickstart calculator to verify your design, especially in terms of compensation (remember to derate the ceramic output cap value for voltage as needed).
    Tim
