Other Parts Discussed in Thread: BQ25790,
Hi team,
Here's an issue from the customer may need your help:
The BQ24179 is used as an external charging IC on the uis8581. The software drive is the drive of BQ25790. The device battery voltage is 3.7V, while the actual charging current is only 200MA, and the charging current for the drive setup is 1A. Below is the hardware design schematic:
Could you help check this case? Thanks.
Cherry
