Good day. I hope you are doing well.
Our customer has the following question about the TPIC71004-Q1:
Can you please help us? Thank you.
Cedrick
1. How should unused squib outputs (ZMx, Zx) be handled/connected? Just unconnected and left floating?
2. What is the intenden size of the SQREF resitor? Matching resistance of the squibs?
3. How should pins TEST1 - TEST4 be connected? Just leave them floating?
4. The datasheet mentions inductors LZx and LZMx? How can they be calculated or is this just a placeholder for wire inductance between squibs and TPIC?
Cedrick
Cedrick,
I have some questions.
Can you send me email (email address : ntake@ti.com) for starting offline communication ?
Norikazu
- Floating is fine. or have a 10nF to 22nF cap to ground to mitigate any noise coupling through these unconnected pins at system level.
- This is to calibrate the gain and offset of the diagnostic amplifier with a known resistor (typically 2 to 6 ohms range matching the unknown squib resistance range).
- Recommended to be connected to ground
- The inductances are the loads typically our squib drivers support. On airbag systems, we have wiring inductance, clock spring inductance that provide about 100uH max between Zx and ZMx.
Norikazu
