Part Number: UCC28C44
Hi Team,
Customer wants to know some more detail how this device can protect from overload, I put my understanding, please help correct, thx.
1) What is the triggering condition of overload protection?
[Andrew] An external series resistor (RCS) senses OC and converts it to voltage at CS pin. The CS input is compared with an internal error amplifier output voltage. When overload peak current is detected, internal PWM generator will stay at zero duty until overload condition is removed.
2) When overload is triggered, beside PWM off, what else device would do? In any sequence?
[Andrew] I think customer is trying to understand if key word 'overload protection' mentioned in the datasheet equal to 'PWM off' ?
3) Right after current-limit is triggered, will current output continue to increase for a while? If so, how do we determine and limit actual max output current?
[Andrew] I think customer tried to understand how to set a absolute current limit (and by which pin) if output current can continue increasing for a while even current-limit is triggered, output short to ground for example.
Thanks!
Andrew
