BQ24707: Confirmation
Genius 9880 points
Part Number: BQ24707
Is it possible to program the charging voltage through an external microcontroller? If yes, is there a guide/app notes that can be used as reference?
Thank you in advance
Maynard
  • Dear Maynard,
    This is an SMBus controlled charger. You can use SMBus to change the charge voltage using the SDA and SCL lines to control Register 0x15 as described in Section 8.5.5 Setting the Charge Voltage.
    Mike Emanuel
    Please click "Resolved" if this answered your question.
