Hi expert,
I`m using CSD17308Q3 Pspice model to simulate in cadence/virtuoso_spectre, it report "Cannot run the simulation because the syntax error `Unexpected end of file. Expected equals sign, numeric value or string value' was encountered at line 1. Correct the syntax error and rerun the simulation" in spectre output log.
The way I add pspice model in cadence is right, I think. Because I have simulated other parts used the same way.
Can you give me some suggestion to solve this problem?
Best regards & Thanks,
Harvey
