LMZ31503: INH/UVLO pin: internal pullup and adjustment sequence
Guru 19655 points
Part Number: LMZ31503
Other Parts Discussed in Thread: TPS54320
Please let me know about two points below for LMZ31503's INH/UVLO pin function;
・About internal pullup, below thread is described "The INH/UVLO has an internal pull-up to Vin".
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1070218/lmz31503-pwrgd-behavior
 But the other thread is described "the internal INH pull-up current source goes to an internally generated 3V, not Vin" .
https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/905974/lmz31503-mosfet-for-inhibit-pin
 Which is correct?
・On the sequence setting, when INH/UVLO connect directory the other PGOOD pin and startup VIN / PVIN earlier then the other DC/DC, LMZ31503 startup is ahead of sequence setting.
 I considering to add below circuit based on datasheet Figure-29.
 If there the other recommend circuit or idea, please let me know.
Satoshi
