Other Parts Discussed in Thread: BQ25710,
Hi Team,
We have a question for PROCHOT behavior when low power mode as blew datasheet shown.
This PROCHOT function is used to monitor system voltage whether VSYS is lower than specific value like a under voltage alert.
We need to use resistor divider for CMPIN to set normal VSYS is higher than 1.2V. But the #PROCHOT will be trigger from high to low when VSYS at normal voltage range.
Could you please help to comment this behavior? Thanks.
Also, I checked the BQ25710 datasheet for this #PROCHOT behavior. It does not include a NOT gate after independent comparator. Are BQ25720 and BQ25710 with same behavior?
Hardy
