TPS737: TPS73701 vs TPS73718 - what is the difference?
Part Number: TPS737
What is the difference please between the TPS73701 and the TPS73718 because I can't see it in the datasheet. (And where is it stated in the datasheet?
Thank you.
             This device is available in Fixed as well as Adjustable output versions. TPS73718 is the fixed 1.8V VOUT version and TPS73701 is the Adjustable VOUT version. This is described in the Device nomenclature section (11.1.2) of the Datasheet. Thanks!
    Srikanth
