Confirmation of Qualification summary of LP5951MGX-2.5/NOPB.
The CDM item says See data sheet, but the data sheet does not contain the ESD-CDM test results.
What are the test results of ESD-CDM?
I am looking into this, I will get back to you within 3 business days. Thanks!
Srikanth
This is a relatively old Device designed by National Semiconductor. Unfortunately, according to the original reliability report, it appears that the CDM test was not performed for this device. Thanks!
Srikanth
I will wait until the result of the ESD-CDM test is obtained, so can you confirm it?
If you do not know this data, it will be difficult for customers to use it.
Please check the following (1) and (2) additionally.
(1)Reasons for not conducting ESD-CDM testing
(2)Can you give me a modified version of the reliability test data?
Hello Akimoto-San,
As I mentioned earlier, this National Semiconductor device is relatively old and the reason for not conducting the ESD-CDM test is not known at this point. It would also be difficult for us to perform this test on old parts. We have more modern alternatives to this device (LP5907 e.g.) which has CDM test performed on them, would you be interested in using them instead? Thanks!
Srikanth
Hello Srikanth
I understand that it is difficult to perform ESD-CDM tests on older products.
Is it possible to get a modified version of the result column of the Qualification summary that can be obtained from the link below?
https://www.ti.com/qualificationsummary/jp/qualsumm/home?actionId=2800
Hello Akimoto-San,
Just so I understand, are you requesting that the Qualification summary results page reflect that the CDM test was not performed for this device? If so, I agree with you and we will work on fixing this. Thanks!
Srikanth
Hello Srikanth,
Thank you for your support and understanding. I would be happy if you reflect that the test wasn't performed on the Qualification summary. Also my customer is in a hurry and is requesting it as soon as possible. Could you please, tell me when the results will be reflected?
Hello Akimoto-San,
I have contacted our relevant quality engineer regarding this, I will get back to you within two business days with an update. Thanks!
Srikanth
