Hi team,
- When LED supply drops and WLS fault is detected, is LED diagnostic still functioning in parallel? E.g., will LED open fault get reported since LED supply is low which may result in LED open fault?
- After software POR, is there any "deglitch" window? For instance, if there is a permanent LED fault, after software POR, customer may observe /ERR pin is high for sometime before it asserts low due to the LED fault - how long do we expect the /ERR pin stays high?
Thank you!
