TPS61022: Intermittent failure . Component smokes.
Part Number: TPS61022
We are having an issue with the TPS61022 with intermittent failure of TPS61022 (U2) being charged by various USB style chargers. Do you think we need diode to pre-bias the voltage? Or is it layout or parts selection problem?
Thank you!
  • Hi Jonathan,
    Thank you for using our device in your application.  The experts of this IC is currently on CNY holidays and they will return to work next week. Please wait for a few days to get their support.
    Youhao
  • Hi Jonathan,
    Thanks for reaching out. Please pre-bias output before you power up the device. You can refer to datasheet 8.3 for reference. For layout. I recommend you strictly refer to datasheet layout recommendation. You have your output capacitor far away from VOUT pin. This is not good. The cross-connection on capacitor's GND lead is not recommended. This will rise the parasitic into VOUT loop.
    -Wenhao
