LMG3410R150: LMG3410R150
Part Number: LMG3410R150
Hello E2E,
the reset of the Fault signal is described by holding the IN Pin low for more than 350 µs. But within figure 17, there is PWM at IN and inspite
of this, the FAULT is reset after treset. Is this correct in the Figure17 or is the description wrong?
Regards, Christian
  • Hi Christian,
    Thank you for your question. Good catch, the figure is marked incorrectly and does not apply to that first description. It corresponds to the second case described in the following paragraph. Thanks for pointing that out, we will get this fixed on our end.
    Noah
