I'm curious about why Buck converter no RHP zero??
Other topologies such as Boost and flyback all have RHP zero stability issues.
Could you give me an intuitive idea about why buck has no RHP zero, but boost have?
The generic answer is because in buck converter deliver the energy during the on time of the High Side FET switch (D time) whereas the other topology delivers the energy during the off time of the switch (1-D time). Therefore there is an inherited "delay" in the buck or buck boost or Flyback topology and that is represented by RHP zero.
-Arief
Hi Arief,
Thank you for your intutive and clear explanation.
For futher question about RHP zero,
Why DCM RHP zero is much far away than CCM ??
Could you still give me some intuitive idea about this phenomenon?
Hi Leo,
I think it is related to the equation of RHP zero location. For example in a Boost, the location of RHP zero is indicated by this equation
Therefore in DCM, Rout is quite large and hence the wr (2*pi*Frhpz) value above is also large. Hence the location of RHP zero also increases
-Arief
