UCC28950: PSFB, shim
Part Number: UCC28950
I am trying to make a Phase shift full bridge with UCC28950.
The leakage inductance is insufficient, so I am going to add it externally(shim inductor).
The toroidal core is overheating, so I am trying to change it to a ferrite core.
At this time, is a gap necessary for the ferrite core?
 Best Regards.
    I generally have magnetic design houses such as Wurth or Renco design the power magnetics that I use.
    I do know that you do not want to use a saturable inductor and they are lossy.  I do believe it will require a gap if you are designing the magnetic yourself.
    If you are going to design the magnetic yourself Mag-Inc has many useful application note that can help with the design.  You can find them at the following link. https://www.mag-inc.com/
