Other Parts Discussed in Thread: LMR33610
I want to use the webench tool to verify the values of the LM22676-ADJ external components for Vin = 7.2V to 12V and Vout 6V 1A. It doesn't recognize the component with these values.
Hello
Your input voltage of 7.2V is too close to your 6V output for this device.
I have created a Webench design with a minimum input voltage of 7.4V.
You can use this design and test on a modified EVM to see if it will work for your application.
Otherwise, you may wish to look at some of our other more recent products, that can regulate from 7.2V to 6V
Could you recommend me any switching regulator that covers the Vin from 6-5V to 7V to Vout 6V 1A?
