my input 9V battery, Want boosted Dual outputs +70V and -70V with 60mA capacity
Please provide circuit schematic
Thank you for using the forums for your applications support needs. You only need to post in one forum for a given request. If your post is not in the right forum, someone will move it to the proper one. I will delete your other posts as they are duplicates of this one.
For this question, the correct forum is most likely the isolated controllers forum. For this high of an output voltage, you will likely need a flyback type topology. This is an topology supported by the isolated controllers team.
You also need to consider if your battery is capabale of supplying the nearly 1A of current required to support a +/-70V solution at 60 mA.
