Other Parts Discussed in Thread: DRA829, TDA4VM
Hi Experts,
Nice to talk with you. TPS6594-Q1 is under evaluation on customer side.
Could you share the difference between TPS6594111/ TPS65941212 and TPS65941213? Thanks.
Best Regards
Songzhen Guo
Hi Experts,
Best Regards
Songzhen Guo
Hello. We have assigned this to the appropriate engineer. He should be able to respond to you tomorrow.
Alex
Hello Songzhen,
They are 3 different versions of the device providing two options for powering the Jacinto 7 DRA829 or TDA4VM processor. Customer can choose between using a TPS65941212 + TPS65941111 pair (PDN-0B) or TPS65941213 + TPS65941111 (PDN-0C). The primary difference between the two is PDN-0C has dedicated MCU and SOC error signal monitoring while PDN-0B uses a combined signal. For more details please refer to their user guides.
