TPSM82810: Difference between 3A and 4A?
Genius 4190 points
Part Number: TPSM82810
Other Parts Discussed in Thread: TPSM82813,
What is the difference betweenTPSM82810 and TPSM82813?
They have same data sheet and  I couldn't find no difference on it except output current..
Do they have same specs?( For example, we can find efficiency graph for TPSM82810(4A version). can I use the graph for TPSM82813 as a reference?)
They use same die and you do some screening?
Go
  • Sorry, I found they have different current limit. So, I'd like to change my questions as follows,
    Do they have same specs except current limit?( For example, we can find efficiency graph for TPSM82810(4A version). can I use the graph for TPSM82813 as a reference?)
    Go
  • Hi Go,
    Yes, all specs are the same except for the current limit.  The graphs apply to both devices.
    Chris
