Hi team,
Here's an issue from the customer may need your help:
Using the BQ24650 as a solar panel charging circuit, it's able to charge and function normally. The battery is unplugged at night, the load and solar panel are connected, and the next day, when the battery is plugged in, the BQ24650 board is unable to charge the lithium battery in full sunlight. The solar panel must be unplugged before it can function properly.
The customer would like to know what's the reason for that. Could you help look into this case? Thanks.
Cherry
