Other Parts Discussed in Thread: TPS92691-Q1, TPS92692
What are the main diferences between TPS92692-Q1 and TPS92691-Q1?
Thank you
Thank you
Hi Ricardo,
Thank you so much for your question. I have looped in our technical experts, and will get back to you within 24 hours.
Caroline
Hi Ricardo,
The TPS92692 is a new part with high side PWM dimming FET driver without having to do a level shifting stage. I also has spread spectrum modulation for better EMI performance. It also has an internal analog to PWM dimming feature. I would recommend the TPS92692 for new design since it's a newer part.
Thanks Tuan
