This is in continuation to to the discussion : https://e2e.ti.com/support/power-management-group/power-management/f/power-management-forum/1071087/lp5562-cisco-led-lp5562-is-very-unstable-some-times-working-sometimes-not-working
we tried the experiment as suggested.
In fact, We do not want to control the loop. We just want to turn on the LED and keep it ON. But this is not working always. Sometimes LED turns ON and some times it does not. Please help.
The Experimented we performed is as below:
TURN LED SOLID RED <-- Say, it turns ON on the device
TURN LED SOLID RED <-- It does NOT turn ON on the device <<<<<<<<< THIS IS THE FAULTY CASE WHERE LED DOES NOT TURN ON. We need help here.
TURN LED SOLID RED <-- it turns ON on the device
Code snippet for "TURN LED SOLID RED" ( This is already mentioned in original ticket by Srinivas):
echo 0 > /sys/bus/i2c/devices/0-0032/run_engine
echo "RGB" > /sys/bus/i2c/devices/0-0032/engine_mux
echo 1 > /sys/bus/i2c/devices/0-0032/select_engine
sleep 1
echo 1 > /sys/class/firmware/lp5562/loading
echo "40FF" > /sys/class/firmware/lp5562/data
echo 0 > /sys/class/firmware/lp5562/loading
sleep 1
echo 1 > /sys/bus/i2c/devices/0-0032/run_engine
Vijay
