Other Parts Discussed in Thread: PSPICE-FOR-TI, TPS65135, , TPS65133
I'm trying to design a split-rail dc/dc converter for measurement system. These parts fit my needs best due to low PCB area. However support in Webench is limited (to only one of the rails) and has the disclaimer to validate designs with SPICE. However there are no spice models in PSPICE-FOR-TI or TINA. I prefer TINA because its fast and much more likely to run to completion while PSPICE-FOR-TI seems to always be slow with so many convergence problems that I often have to give up on it. The other issue is that the semiconductor shortage means that I'm never sure if a part is available even for a small run of prototypes, so I need SPICE models for other power supply parts to create backup designs, which often don't have them either.
