TLV733P-Q1: load regulation 1-100mA
Part Number: TLV733P-Q1
hi, what is load regulation for 0-100mA range? is it 1/3 of full load spec (typ=25mV at 300mA)?
  • Hello Ito-San,
                          To a first order approximation, it is safe to assume that the line regulation will vary linearly with the load current range. So yes, for 0-100mA range, you can assume that the change in output voltage for this device will typically be one third of 25mV. Thanks!
    Srikanth
