Hi Team,
just want to check if we do surge test on TPS22913 and what's the surge capacity of TPS22913.
background is that my customer found failure on TPS22913 during surge test on their products, so they want to check on it. Thanks.
BRs
Given
Hi Team,
BRs
Given
Hello Given,
Which test are you referring to specifically? Below is our Qualification summary for this device.
Kalin Burnside
Hi Kalin,
Thanks for your reply.
What I mean is the surge test,add surge voltage (a large transient voltage and there is standard) on Vin (EN is connect with Vin) to see if the part will be damaged.
BRs
Given
Hello Given,
Yes, I was asking which standard. Regardless- no surge tests were done on this part since it's intended for personal electronics. ESD and latch-up were done instead. This device isn't meant for situations in which a surge would occur.
Kalin Burnside
