Other Parts Discussed in Thread: TPS745
Dear team,
My customer wants to know whether Config level can be changed. How to achieve >70% Config level?
Thanks & Best Regards,
Sherry
Hi Sherry,
Here is what he said:
For sample population with zero reliability fails the 70% CL FIT is 1.31x the 60% CL FIT .
The inverse chi square function in excel can be used to calculate the scaling factor to use to go from one known confidence level to another.
Scaling factor = CHISQ.INV(70%,2) / CHISQ.INV(60%,2) for sample population with zero fails
So for this example, the 70% CL FIT is 0.2 * 1.31 = 0.26
Nick
Hi Nick,
Thanks for your help!
I am not sure whether I understand your point, could you please help check whether my understanding is right? In my understanding, This scaling factor 1.31 is calculated by this formula, CHISQ.INV(70%,2) / CHISQ.INV(60%,2). If we want to increase the Config level, we need to increase the FIT value to 0.26 firstly. But I think the FIT value is fixed for specific device. How to increase the FIT value of TPS745?
Sherry
Hi Sherry,
The FIT rate is not really constant for a device. The way to interpret this is that for a given sample size, if we measured the FIT rate, with 60% confidence we will measure 0.2 or less, and with 70% confidence we will measure 0.26 or less. They can use the equation to approximate any other confidence level by scaling from the 60% confidence level as well.
Nick
Hi Nick,
I don't find the inverse chi square function in excel. Could you please tell me where I can find it?
Sherry
Hi Sherry,
The inverse chi square function in Excel is as in the formula above:
CHISQ.INV(probability,deg_freedom)
Nick
