Hi Team,
Good day! Could you please check the datasheet on page 13 regarding the the temperature sensing calculations.
As per customer below:
I am using a vishay 1k Ohm PTC thermistor with an RTH of 1084 k and an RTC of 900 ohm.
The equation in the datasheet gives a negative resistance for RT2.
As the datasheet gives a negative resistance for RT2 I'm assuming either I'm doing the calculation incorrectly or theres a problem with the equation.
Thats the one. Page 13. By my calculation
Thermistor: PTC Vishay TFPTL10L1001FL2B Thermistor, L10 1kΩ
RTH: 45degC = 1.084 kohm
RTC: 0degC = 900 ohm
From the equation on page 13:
RT1 = 8.837 kohm
RT2 = -1.180 kohm
Thank you in advance.
Jonathan
