BQ28Z610: Wrong file format for GPCCHEM
Part Number: BQ28Z610
Other Parts Discussed in Thread: GPCCHEM
I'm continuing to send the zip file to GPCCHEM tool, but I receive this answer:
The following errors were reported by the calculation engine:
Error: Wrong data format make sure file has coma or tab separated values. Name: roomtemp_rel_dis_rel.csv
I had tried with this separator : comma, semicolon, tab
Thank you for your help
  • Hello Stefano,
    Can you post the file?
  • 2xICR13775.zip Now I have understand how place attachment
  • GPC tools only accept comma or tab separated values
  • ProcessingType = 2
    NumCellSeries = 2
    ElapsedTimeColumn = 0
    VoltageColumn = 1
    CurrentColumn = 2
    TemperatureColumn = 3
    Column numbers start with 0. Here is the corrected config.txt
  • Is working correctly now; Thank You Shirish.
    Best Regards
