Hi team,
I would like to check for below items with TL750M-Q1
1. What is the difference between current consumption and quiescent current? One is 60mA and one is 6mA , as this influence a lot the power dissipation
2. What is the maximum junction temperature? In recommendation operating conditions the max junction temperature is 125C. In customer evaluation should they consider any derating to keep max junction temperature even lower?
The max junction temperature is 150C. What will happened to the IC when Tj between 125C ~ 150C
Ethan
