TPS563208: Power Design Spreadsheet
Part Number: TPS563208
Can I have a power design spreadsheet which shows how to select input and output capacitors base on design specification? The part numbers are
TPS563208DD
TPS548A20RV
TPS562208DD
TPS65265RHB
Please let me know if I need to create a ticket for each part number. thank you.
  • Hi Kang!
    1. This is low-current team support devices with <6A output current. About TPS548A20RV, you can create a new ticket our high-current team team will solve your problem.
    2. About TPS563208DD, TPS562208DD, TPS65265RHB,please provide the application parameters, such as input voltage , output voltage/current.
    BSR-MV-LC
    Shuai
