Hi all!
I have installed TPS92520 Launchpad Evaluation Software without errors. But when I try to run LED_Controller_GUI_LP.exe this error occurs:
Does anybody know a solution to this issue?
Thank you in advance!
Kind regards
Daniel
Hi all!
Kind regards
Daniel
I know this is probably a stupid thing to do, but did you uninstall and then try reinstalling it? If that doesn't work I will get our GUI guy to help you out.
This s a known issue related to Windows language settings. Please try this version of the installer located here.
I am also not able to run this version because of the following error:
Then I changed the language settings as shown in the following picture and now I am able to run the first version.
But every time I try using the slide bars for Analog Current, On Time and PWM Settings, the application closes immediately. Do you know the reason for this issue and how to solve it?
Please see this document on how to resolve the slider issues you mentioned using language. Try changing "Regional Format" to "English United States". The issue is the floating point values parsed by the sliders are not in the correct format. Note also that your version of the GUI will not provide the information in the about box referenced in the document.
