Other Parts Discussed in Thread: LM66200, TPS2116, TPS22953,
Is it ok to use 2 chips in parallel to double the current handling capacity? If not, do you have other chip to recommend? The specs are: Input voltage 1.5-5.5V, output current >= 2A, an output to turn on another path when this chip blocks the output.
Ben
