Other Parts Discussed in Thread: GPCRB, BQSTUDIO
We have a few questions regarding the BQ27742-G1 after recently getting our Chem-ID from TI.
- After updating the chemistry, there was a prompt to update the ‘target bqz container’ (see attached ‘ChemID-Update-Screenshot’). Will this affect the FG config in any way? How do I go about updating the bqz container?
- Is there a need to run any learning cycles once the chemistry is updated? What is the procedure?
- There appears to be an issue with tracking capacity and SoC correctly at cold temperature (-20C) as shown in the attached picture ‘TI_FG_ColdTempPerformance’. We are using the Arbin capacity as our baseline for comparison. How do I go about calibrating the FG for better low temp. accuracy? Will this improve with learning cycles? We came across the GPCRB tool but are unfamiliar with the procedure. Is this needed for better tracking at cold temp?
Thanks!
