Hi team,
Here's an issue from the customer may need your help:
Regarding SMBC and SMBD, a typical circuit does not have parallel capacitors at both ends of the regulator, but the customer want to pass high ESD requirements.
They've added capacitors at both ends of the regulator. The question is 100pF capacitance is OK, but 100nF capacitance cannot communicate. What's the reason for that?
Could you help check this case? Thanks.
Cherry
