Other Parts Discussed in Thread: AWR1843, TPS65131, TPS65653-Q1, , LP87745-Q1
My customer would like to design a AWR1843 system with functional safety supported. They checked the app note slvaeo0.pdf and found there is a System Level Detailed Block Diagram.
They thought the block diagram is designed to support functional safety. They would like to know what this system will do when TPS65313 or TPS65653 is undervoltage or overvoltage.
When undervoltage or overvoltage happens:
From the datasheet of TPS65313, we know the PMIC will disable the issue output channel and can send out signal to reset of the primary system MCU or DSP.
From the datasheet of TPS65653, external processor can be interrupt by the nINT pin.
AW1843 may not work normally in this condition as some of the power rail is abnormal.
Customer thought in this condition, the system power its self should be reset or restart, but they don's see such design in the block diagram. Would you pls kindly help?
My suggestion is to use the watchdog signal of TPS65131 to trigger external circuit to reset the whole system. But customer would like you to suggest what the system you design will do in this condition?
Chris
