TPS61194-Q1: questions about start up and shutdown sequence
Part Number: TPS61194-Q1
Other Parts Discussed in Thread: TPS61194
Hi team,
I received some questions about TPS61194-Q1 start up and shutdown sequence. Please support.
  1. Figure 19 mentions the period T = 50us from VDDIO/EN to LDO shutdown. I think the CLDO is 1uF. My customer is using 2.2uF for CLDO but, is there any effect for the shutdown period?
  2. Figure 18 mentions BOOST START=50ms but actual BOOST START time is much much shorter as shown in Figure 23. Please provide correct value of BOOST START time.
  3. How much tolerance should we expect for SOFT START time of 65ms and BOOST START time?(expected answer is +/-10% or so)
  4. My customer controls an OUT-pin by transistor and turn off the channel if the LCD has only 3 strings. When does TPS61194 sample the OUT pin voltage to check use or unuse?
