Because of the holidays, TI E2E™ design support forum responses will be delayed from Dec. 25 through Jan. 2. Thank you for your patience.
TPS274160: Current Limiting across Channels unknown
Part Number: TPS274160
I cannot find information on the current limiting function of this HS Switch. I am wondering if 1 channel has a short to ground condition, do all of the FET's clamp, or does only the one going over current limit, i assume the current limit is total current, not current per channel? is there better documentation on how this happens?
