Other Parts Discussed in Thread: DAC53508, LM10011
for Adjustment of dual DCDC LM5143QRWGRQ1 Output Voltage:
- Since I didn't see any application note for Adjust Vout under this component, do you recommend using the same technique with DAC?·
- If yes, DAC53508 should be OK?·
- If not, can I use a digital potentiometer in series to the feedback resistor R2?
