Hello Team,
I developed a BMS with BQ76952 for a 48 V swappable battery system and it is working fine.
I have noticed one thing. When packs are connected in parallel HV packs starts charging the LV packs. This should not happen ideally, for this I am planning to implementing Common Source configuration fro Chg/Dsg FETs. Can BQ76952 handle Common Source Config?
Both the Chg/Dsg are ON since it is not recommended to flow current through body diodes.
Is there any better way to stop HV pack to LV pack charging phenomena from happening?
Thank you!
