Part Number: TPS57114C-Q1
Other Parts Discussed in Thread: TPS57114-Q1,
what is the difference between TPS57114QRTERQ1 and TPS57114CQRTERQ1
Hello user,
Please refer to the e2e thread below:
Let us know if you have any further questions.
Thanks a lot!
Dorian
Could you please tell the technical difference between tps57114-q1 and tps57114c-q1 ?
And What is the main reason to stop the tps57114-q1 production ?
Hello user,
The replacement part is TPS57114CQRTERQ1, the same device (drop-in replacement with same data sheet parameters) but with improved quality. The only difference between the two part numbers is an added polyimide layer providing a much improved robustness and quality performance.
Thank you,
Dorian
Could you please give the difference table for TPS57114QRTERQ1 andTPS57114CQRTERQ1 ?
(Because I can see some difference in Thermal resistance )
Can you describe what are the differences you see in the Thermal resistance ?
This added polyimide coating is the only difference between the two parts.
Let me know.
Thanks a lot!
Dorian
I don't know why your message is not visible but I saw the image you sent us.
Both TPS57114C-Q1 and TPS57114-Q1 share the same performance. You can see in the latest datasheet of TPS57114, on page 5, from revision B to revision C: -"Corrected values in Thermal Information table"
The photo of the datasheet you shared earlier was realized before revision C, that is why you see a different value.
Let us know.
Dorian
