TPS929120-Q1: ADDRESS SETTING
Part Number: TPS929120-Q1
Request your inputs on below:
1. If we use 14 pieces of TPS929120-Q1,we need to set these IC‘s adress first .How  master  controller finds  the slave device(TPS929120-Q1)  before setting the address? For example, master controller intends to set the slave device address to Dh, how does the master controller find this slave device?
2.How  to  design the circuit of  TPS929120-Q1 to support setting address. Such as ,how to deal with the pin ADDR0、ADDR1、ADDR21、REF and so on?
Thank you!
