LMS1585A: Output pins
Part Number: LMS1585A
Hi Experts,
Figure 2 on the front page of the datasheet labels the tab pin as "Vout" and pin 2 as "OUTPUT" from what I understand, in TO-263 packages, both pin 2 and the tab are connected internally. Can you confirm if these pins are both Vout?
Thank you.
Marvin
  • Hello Marvin,
                         This is a relatively old device, and we do not have much data description beyond what is provided in the Datasheet. Based on the description provided in the datasheet, yes, the tab pin and Pin 2 are both VOUT. Thanks!
    Srikanth
