Utilization of R D K - B D C 2 4
Dear Sir/Madam,
We're the one of the best known R&D company in Turkey. We're working on a project for our valuable customer. We may have an opportunity to cooperate on this project.
We're planning to use R D K - B D C 2 4 to drive Permanent Magnet DC-Motor GR 63x55 from the company of dunkermotoren ( you can check the detailed specifications at the following link if you want) http://www.dunkermotoren.com/default.asp?id=9&mid=12&lang=2
http://www.dunkermotoren.com/data/technical_data/motors/pdf/GR%2063x55.pdf#page=1
We're planning to use a AC/DC Converter to use the whole system at the rated power.
The "most important" thing to choose a power supply is reliability of the system and long life expectancies.
We'll be glad to inform us about suitable design.  Please inform us if you'll not offer a suitable design.
Ali Er
Phone : +90 542 3818102
  • Texas Instruments has a wide range of power supply solutions.  If you work with your local TI representative, they can help you to select the correct ICs so you can design your solution.  TI's home page, www.ti.com has a link, Contact Technical Support, that can help get you in touch with a local engineer.
