Dear All:
Do you know what conditions cause the DSG FET be latched low status?
Dear All:
Any safety related protection will trigger DSG FET to be turned off.
Please refer to the data sheet, Li-ion protection and Permanent Failure sections.
Thanks a lot!
But what conditions would cause DSG FET be always latched off status?
I met one stronger symptom that DSG FET was always off status and voltage is to full status.
Example:
Released condition that device detects did charging action;
2. Short current;
When the short condition be released , Device would recover to normal automatically.
Any of the permanent failure conditions will blow the fuse and keep both CHG/DSG FETs in the off state.
Hi Jackie:
Only DSG FET is off status, CHG FET is on status;not PF raised;
This battery pack be inserted into the host system, and charged to full, then put into -20 for 2hours.
Turned on the host system, observed DSG FET be latched to off status.
Do you have any suggestion ?
It looks to me like the gauge may have had a CVUV at some point but has since recovered. The curious thing here is that your capacity does not match up with your cell voltages at all.
