We are using a TI chip….the TPS65232 on one of our boards, and I have a question about the enable inputs.
Can I use three FETs to pull down the 3 enable pins to create a Power Reset on my board. I was concerned about how this would work with the internal current sources inside the part tied to those inputs. On pg 10 of the data sheet the verbage indicates the enable pins can be grounded but the diagram shows a current limiting resistor between the switch and the enable pin. Or, does TI have a better way to accomplish the same thing.The TPS65232 supplies power to all other parts on the board.
Thx,
