Part Number: LM61460EVM
Do you have any transient (0.05A<->6A) test results based on LM61460EVM in PFM mode? i would like to know performance for 3.3V and 5V output.
-A
-A
Hi Elena,
Is it using EVM, same LC configuration for test? Could you please confirm? You know the transient performance without specific L-C will be meaningless.
-A
hi, Albert,
Yes, usually the waveform on datasheet is from the EVM board.
Elena
HI Elena,
Do you have a more clear waveform for below 4 waveforms? The undershoot and overshoot spec is vague and I cannot tell the exact number. Thanks!
hi, Albert,
This is published on datasheet of LM61460Q, so that's is the final result we have. Vout is 200mV/DIV, the worse case should be 300mV around.
Elena
