LM2673: Current adjust pin - Radj set to 0 Ohm
Part Number: LM2673
We use LM2670SD-5.0/NOPB in our designs. Alternatively we now want to evaluate the use of LM2673SD-5.0 in our designs. Therefore the Pin number "6 current limit adjust" must be tied to ground via a resistor with the formula Icl = 37,125/Radj. Is it possible to set the resistor to 0 Ohm? I found nothing inside the datasheet which forbid that but not enough details to be sure about it.
Thanks in advance for your help!
Bastian
