TPS61032: Low Battery Indicator lights lights up before the design value
Part Number: TPS61032
Hi TI,
I have made a low battery indicator light using the TPS61032. but the light seems to slighty turn on as the battery is getting drained. The voltage is currently 2.5V and the design value was 2V and the low battery light is active (low but active).
It may be the red light that activates at low voltage, the low battery light part number is : KT-0603R.
Can you help me figure out the issue ?
Andy
